unconfigure policy syslog
unconfigure policy syslog {machine-readable} {extended-format} {every-time}
Description
Resets Syslog parameters for policy rules to their default settings.
Syntax Description
syslog Designates unconfiguring selected Syslog parameters for policy rules.
machine-readable Clears the control for device formatting of rule usage messages to the default setting of disabled (decimal format).
extended-format Clears the control for extended rule usage message formatting to the default setting of disabled (not extended).
every-time Sets the Syslog message sent on rule usage to the default of on first usage only (disabled).
Default
By default, Syslog messages are only sent on first use of a rule.
By default, extended-format and machine-readable are disabled (not extended and in decimal format).
Usage Guidelines
This command allows you to reset parameters to their defaults for Syslog messages that are sent when a policy rule is used as set up in the command configure policy rule profile_index [{app-signature group group name name} | ether ether | icmp6type icmp6type | icmptype icmptype | ip6dest ip6dest |ipdestsocket ipdestsocket | ipfrag | ipproto ipproto | ipsourcesocket ipsourcesocket | iptos iptos | ipttl ipttl | macdest macdest | macsource macsource | port port | tcpdestportIP tcpdestportIP | tcpsourceportIP tcpsourceportIP | udpdestportIP udpdestportIP | udpsourceportIP udpsourceportIP ] {mask mask } {port-string [ port_string | all]} {storage-type [non-volatile | volatile]} {drop | forward} {syslog syslog} {trap trap} {cos cos } {mirror-destination control_index} {clear-mirror} .
The following clears the setting for when Syslog messages are sent when a rule is used to the default of only on first rule usage:
#unconfigure policy syslog every-time
This command was first available in ExtremeXOS 30.2.
Platform Availability
